I have a 97 pathfinder and went to do a stereo swap from some one elses mess to a more up to date 7in touchscreensoundstorm DD888well im got video but no sound ...could this be atributid to the bose system acting as interferance- and if so is there a diagram avail. to remove the BOSE system or any one know any back door solutions to get me around the issue -thanks
SOURCE: 2002 Altima Factory Bose Audio ERR3
there are only couple options. pull radio and send to shop for repair, purchase used radio from good junk yard. or call dealer and see if there is a warranty on it. even though its 6 yrs old they may help. what they do at the dealer is an exchange
SOURCE: i hooked up a new radio in my 96 nissan maxima and get no sound.
Hook up the Amp Turn on Wire usually blue/white strip
SOURCE: My bose car stereo system
i had multiple problems with my stereo in my terrano just recently. first started with the digital trip meter going out and no audio, that was to do with the earth cable which came from te car. on mine it was a pink and silver cable, maybe it was done wrong from who ever wired it in first but it didnt like it so i went straight from the head unit to the chassis... secondly it could be the amp control cable. it may be loose or something. and thirdly a problem my friend encountered with his stereo was that the unit would turn on but no audio and after sctatching at our heads for a while we thought we'd go through from behind the head unit and remove each speaker when we took one out of the equation we got audio and it was because the speaker was shorting against the car body which would prevent any other speaker from working. hope these help. as for the dimming im not quite to sure maybe get a multi metre onto the power and see if its reading 12v.
SOURCE: How to Remove Car Radio from Nissan Murano
If you disconnect one of the battery cables for about 30 sec and reconnect it, that will reset the CD player. Then you can put in the key and see if can eject the offending CD. My bet is that it won't. I own a 2006 with a failing CD (getting it replaced on warranty next week). The CD player in these cars is a real stinker. Nissan should be ashamed.
