HP LaserJet 4 plus Printer Logo
K
Kar May Kwong Posted on Mar 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please give me detail instructions, step by step because not very computer literate to solve printer problem. Flashing green "PC Load A4" causing printer not to print. Thanks CK
  • paulgbrandon Mar 15, 2015
    Hi Kar May Kwong, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What computer application are you using to print? By computer application, examples are Microsoft Word, Microsoft Excel, etc.
John Bevan
Level 2:
Novelist:
Scholar:
  • Expert 80 Answers
  • Posted on Mar 15, 2015
John Bevan
Expert
Level 2:
Novelist:
Scholar:
Answers
80
Questions
0
Helped
10348
Points
100
What this means is that the print job you sent to the printer is formatted for and designated as being ready for printing on A4-sized paper, which is a European size that is 210 millimeters wide by 297 millimeters tall. This is close to what Americans will refer to as letter size as that standard is 8.5 inches by 11 inches while A4 is 8.27 by 11.7. If you have standard letter-size paper loaded into the printer and you want to print on such paper, then you need to go into whatever program you are using to write the document (for example, Microsoft Word, Corel WordPerfect, etc.) and set the option in the Print... dialog window to print on Letter rather than A4. You also need to cancel the print job currently in the printer. This is done by holding the Shift key on the top of the printer and pressing the button that says "Reset" underneath it in purplish-red. This will flush the memory of the printer and make it ready for the next print job. As it's been a few years since I last worked on one of these printers, I cannot remember if you also need to hit the Online button first (so that it is offline, indicated by the light being turned off on said button) before you can reset the printer but if so, then just hit that button, reset the printer, and then hit the Online button again to bring it online.
This should take care of the problem for you. If you have any other questions about this issue or other concerns about your Laserjet 4 series printer, feel free to drop me an email. You can find me at Best Deal Computers as I am the owner. :-)
2answers
How to fix PC Load A4 printer problem
A4 refers to a paper size, so its asking for that size of paper to be loaded.
3answers
Error Message on Dell 5100cn
check the page setting in the printer as well as in the print dialog box in the, if the problem persists then you have to send it for servicing
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Getting an alert saying: PC Load A4 What do I do?
Load A4 paper. Or just press the green button to force it to print to whatever paper is in the tray.
1helpful
Why doesn't paper feed after "print" instruction? Printer merely makes a mechanical noise and states "paper out" condition.
Hello.
There are lots of reasons why this would happen:
Foreign object (could be very tiny)
Any power lights flashing ?
Paper feed rollers may need cleaning - try (from Canon Support):
1. Ensure that the printer is turned on. If any paper is loaded in the printer, remove it.
2. Select which roller to clean, the auto sheet feeder's or cassette's, by pressing the <Paper Feed> switch on the printer.
3. Hold down the <Resume/Cancel> button; when the Power lamp flashes green three times, release the button. The paper feed roller will rotate as it cleans itself.
4.. Repeat step 3 twice.
5. Load three or more of A4 or letter sized plain paper in the auto sheet feeder or cassette, as selected in step 2.
6. Repeat step 3. The paper that is loaded in the printer will be fed through the printer and ejected.
7. If printing problems persist, repeat step 6 up to three times.
Could be a hardware error and the printer would need servicing - still under warranty ?? If so, return to Canon for repair or replacement.
Hope this helps.
Error message 0xf0af8005 and green and orange flashing lights
Please follow these instructions to reset the printer. If that doesn't work, try again but wait longer before reconnecting. Otherwise, here's the home support page for your machine. You can look up the meaning of the flashing lights there as well.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
3helpful
2answers
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
1helpful
I am using a HP Laserjet 4 plus. I got a flashing "PC" and "Load A4" on the screen and could not print. Pleas help.
Clear the Print Que in the PC, turn off and unplug the machine, turn it back on.. send a test print from the driver.
A4 is european paper size, your printer is set for letter, someone attmepted to print an A4 file. Which is in the page set up in what ever file was to be printed.
Next Time Please be specific?
A4 IS COMING OUT GOOD BUT A3 IS BLANK?
there is one setting on u r printer properities ..please check it if u can not solve problem please download team viewer using below link install on u r pc & give me call on Gtalk my mail id is [email protected] .....
useing teamviewer i can remotely acess u r pc & check it settings of printer ..
link for Team viewer
http://www.teamviewer.com/download/index.aspx
k24674
Grand Canyon Tech
Grand Canyon Tech
