Ovens Logo
r
raju ronin Posted on Mar 07, 2015
Hi, Looking for a wiring/electrical diagram for Neff D39F56S0GB Extractor hood. Or could you Kindly point me in the right direction. Thank you
NEFF Extractor HOOD model D39F56S0GB Electrical Diagram Wiring Diagram Electrical Circuit Diagram Electric Schematic Wiring Schematic
Michelle Sullivan
Level 1:
Habit-Forming:
New Friend:
  • Contributor 5 Answers
  • Posted on Jul 07, 2015
Michelle Sullivan
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
5
Questions
Helped
5286
Points
8
You can find the manual here:
D39F56S0GB/01
and here:
D39F56S0GB/02
It should come with a cable attached which should conform to standard wiring colour codes.
Red/Brown = Live/Feed
Black/Blue = Neutral/Return
Green/Green & Yellow = Earth
If the standard cable has been cut off there is a good chance it was for a reason and you shouldn't try to connect it without knowing how to determine which contact is for which (an electrician/electronics tech will know within seconds what should be connected where.)
5 Related Answers
Anonymous
  • 709 Answers
  • Posted on Nov 23, 2007
SOURCE: Electrical supply
HI Zuso,
Use your original wire and hook up Left to right Line Neutral, and Ground. L N G. Black wire is Line. Green wire is Ground. not sure what UK uses for Neutral. I just know that you need a big wire. And the voltage is supposed to be 220-240Volts.
Anonymous
  • 250 Answers
  • Posted on Jan 20, 2009
SOURCE: schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Feb 10, 2009
SOURCE: neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Anonymous
  • Posted on Aug 30, 2009
SOURCE: Electric Diagram for Kenmore Model 790
I have a Kenmore Model 790.91062601 and it has stop heating. None of the burners or the oven will heat. Any solutions
Anonymous
  • 250 Answers
  • Posted on Jan 26, 2010
SOURCE: Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Where can I get installation and operating instructions for a NEFF 29c warming drawer?
Hi Pat,
I suggest contacting Neff directly. You can email them or telehone them from choices on the page linked below:
http://www.neff.co.uk/customer-service.html
Apr 14, 2015 • Neff Ovens
Neff oven wiring diagram
It does not really matter which wire goes where. The red one would be live and the blue would be neutral, but on an oven element they could go on either terminal. Just make sure that everything is turned off when working on the oven etc.
The door to my Neff oven is not closing so heat is escaping from the top - please help
You need new hinges use linkhttp://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?Maktx=b1644&eshoptype=A
click on the spares listing for your model (you will need the full Enr from the oven rating plate) and order the hinges (always replace as a pair). Hinges are on page 3 parts list in position 0319 and 0320 (these are not the parts numbers, you need to highlight these positions numbers on the breakdown from your specific model to get the correct part number (six digit part number) You may find that although the position number are different for the left and right the actual part numbers are the same. You can add the items to the basket and order directly from Neff.Hope this helps
1helpful
I am looking to download a manual for a neff oven,
U HAVE TO TYPE IN GOOGLE DOWNLOAD AN INSTRUCTION MANUAL FOR A NEFF OVEN
3rd blown element
no connection between lights on fan. problem is that bulbs these days are poor quality (but cheap)
it is common for these circular elements to go. usually last about 2 years. worth checking tho that fan is turning at right speed
Neff cooker model b1422nogb bulb replace
Neff B1721 oven
good day,
hope this link below will solve your problem.
kitchen appliances
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
