It can be done, but will take b bit of knowledge.
try these YouTube video's
How to do it run 3 phase motor on single phase supply part 1
How to do it run 3 phase motor on single phase supply part 2
How to do it run 3 phase motor on single phase supply part 3 How to do it 3 phase motor conversion Part 4 the start capacitor How to do it 3 phase motor conversion Part 5 relay start How to do it 3 phase motor conversion part 6 the start relay
Very good video's . Thanks
It might. Mounting holes match? Shaft diameter and adapter match? Power supply sufficient for 5HP motor? It's a big motor! You might get a better answer from the ebay supplier.
Testimonial: "Mounting holes do match and I do have sufficient power supply to run a 7.5 hp single phase motor. Now in regards shaft and adapter that's a good question !!! I just purchased this compressor and it came with a none matching fried 3 hp 1 phase motor on it. Original motor long gone. I do know this compressor originally came with a 10 hp 3 phase motor on it. How important is it to know the shaft diameter on the original motor ?"
Mounting holes do match and I do have sufficient power supply to run a 7.5 hp single phase motor. Now in regards shaft and adapter that's a good question !!! I just bought this compressor and it came with a none matching fried 3 hp 1 phase motor on it. Original motor long gone. I do know this compressor originaly
came with a 10h hp 3 phase motor on it
How do you drive compressor? If belt drive, not a problem, just match belt sizes and appropriate diameter of pully. If direct drive that's when its a problem. If original was 7.5 hp, depending on speeds you need to drive the compressor slower to compensate for lower horsepower.
