Apple iPhone 3G Black  Smartphone Logo
A
Anonymous Posted on Feb 28, 2015
Find flash contact for iphone 3GS
I am unable to make the flash operate when taking photos
Sheldon Dedek
Level 3:
  • Master 912 Answers
  • Posted on Mar 01, 2015
Sheldon Dedek
Master
Level 3:
Answers
912
Questions
0
Helped
306846
Points
3298
The iPhone 3GS does not have a flash. The iPhone 4 was first model.
Some battery / charging cases (lenmar is one) will have a light that you can turn on independent of the phone. That will be your only option.
1helpful
Flashing IPSW in iPhone 3gs
you should still be able to do it the sound has nothing to do with that the best place to find an answer for this question is youtube, everything you want to know about the Iphone is in there good luck
Have iphone 3gs need to update ios to 6.0 or later
The iPhone 3GS is partially supported by iOS 6. It is not supported by iOS 7 or subsequent versions of the operating system at all. iPhone 3GS 8 16 32 GB Specs iPhone 3GS A1303 MB715LL 2315 iPhone2 1...
Download iOS 6 1 6 for iPhone 3GS and iPod touch 4G iphone-3gs-need-update-ios-6-0-or-later-ucocffsbdgqp14shduy2nfxr-4-0.jpg
Iphone problem
Hi, sorry to hear you're having this issue. I would recommend saving all of your settings (photos include) on your computer and restoring your phone to factory settings.
Unable to run whatsapp in iphone 3gs
This iphone repair is rated EASY.
please update your software and you will be able to use all new apps. whatsapp dont support software version 4.1 it has to be 4.3 or up.
1helpful
How do I delete the photo stream albumn or images in it on iphone 3gs
Hi There
Its very simple to delete photo or photo stream to you iPhone 3gs
  1. Press the menu button and select photos.
  2. Select Camera Roll option and now hear you can get you all capture photo
  3. Now select which photo you want to delete, when you select the photo you saw option in you down right side like -(dustbin)
  4. Press that option now the pop up appear two option "Delete & Cancel" chose Delete option.
  5. Now you photo is delete if you want multiple select then you see in corner side "Multiple select option" select that one now you able to delete multiple photo in one time.
  6. Select which photos you want to delete.
See the video for halp
Video 1: Simple Delete
Video 2: Multiple Delete
3helpful
2answers
What is the differeance between iphone g3 to phone gs3?
the main difference between the iphone 3g and iphone 3gs is the speed. but here are the specifications for both phones
weight: the 3gs is slightly heavier at 135g memory: iphone 3g only has two options an 8gb or a 16gb whereas for the iphone 3gs it has 8gb/16gb/32gb camera: the iphone 3g has 2mp camera that can only take pictures while the ihpne 3gs has a 3.15mp camera that can also capture videos cpu/processor: iphone 3g has ARM 11 412 MHz, PowerVR MBX-Lite graphics while the iphone 3gs has 600 MHz ARM Cortex A8 processor, PowerVR SGX535 GPU. So the 3gs is faster and it means less or no lag on apps
the 3gs has a digital compass
and the 3gs has a longer battery time than the 3g.
to summaarize, the iphone 3gs is faster, has longer battery life, and has a bigger memory (as it comes with a 32gb version).
4answers
Trying to bluetooth from blacberry curve to iphone 3gs how do i do this
You cant due to firmware restrictions Iphone has a lot of em
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
