SOURCE: My voicemail indicator message lamp stays on.
What voicemail do you have?
Vm Pro or embedded?
If voicemail pro, you will need to navigate to the folder where your messages are stored on the pc, delete them, then stop/restart the vmpro services. If you dont know what I am talking about, I would call someone in that is a knowledgeable tech....
SOURCE: change main number voicemail
There is no default way to do this. The technician that set the system up will need to tell you the code to get in aand modify that wav file. There is no way to do so by default, it has to be set up, and can be anytihng.
Look at your config, for a short code that goes to a "vociemail collect" with the name recordings.....that is the code you use to modify.
SOURCE: Can't change voicemail on my 5410 Avaya digital phone
Press the voicemail button and enter whatever extension number you are trying to change. Kisten before you record, to make sure you are in the right place.
The auto attendant greeting, or the general mailbox greeting?
