Epson Stylus C86 InkJet Printer Logo
M
MARTIN Posted on Feb 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
EPSON E520 PRINTER WONT DO ANYTHING SAYS ERROR E520
drvalentine
Level 3:
Master:
  • Master 876 Answers
  • Posted on Feb 26, 2015
drvalentine
Master
Level 3:
Master:
Answers
876
Questions
0
Helped
255337
Points
4299
E520 is an error of the 2nd BTR (2nd rollers of transfer)
I have an Epson 545, as soon as i turn it on i get an error (no code) to turn off/on. this does nothing. it doesn't even sound like it is trying to do anything. nothing moves
I think your Epson printer got stuck due to technical issue. After turn off/on your printer hasn't respond that means your printer have these issues:
·Outdated printer drivers
·Any object stuck
·Dirt inside the printer
·Outdated printer firmware
·Ink cartridge not installed properly or damaged inside and more In this situation, you need to contact Epson printer experts through Free live chat. Find here more Epson printer solutions.
1helpful
Error 4d epson wf-2650
i cant find anything on that error. i suspect that the scanner unit is physically broken and it wont move when the printer goes through its startup process.
You can try unplugging it from the wall while it is still turned on
wait 20 minutes or so and then plug it in again
that should reset the entire printer
But if there is something physically broken in there the error will just pop up again.
You would need to have it repaired or replaced frankly its probably cheaper to just buy a new one.
How to fix Epson L210 Printer with these errors: -2 Red lights blinks together -No error appears on screen -It prints for few pages but the error on the printer gets back again ang again Please
Epson printer blinks both red and green lights, which means the paper gets jammed in your Epson printer. You can fix the issue using the steps:
HOW DO I FIX EPSON C8600 E520 ERROR?
This site:
Thread Epson Aculaser C8600 Service Req E520
says, "If you're not a technician, I'd suggest doing what the error says and calling a qualified service organization."
Wont print the right Colours?
try cleaning the heads. That should put the colors back to correct. Sometimes happens with generic ink then have to clean heads more often and you'll have better picture.
16helpful
Error e520
E520 is a 2nd BTR sensor error. It is usually caused by waste toner getting on the sensor. Turn off the printer and open the top panel. Lift up the orange handle to unlock the PCU and remove the PCU by lifting it up using the carry handle. Be careful with the PCU drum as it is easily scratched and avoid bright light. Inside the printer on the rear "wall" is a spring loaded cover which can be pushed down to uncover the sensor. It will stick in the down position, do NOT try to force it up again (it will spring back into the right position when the PCU is refitted). Give the sensor a wipe with a soft cloth and refit the PCU. Close the lid and turn back on, with luck all will now be well. If you still have the same error it is time to get proffessional help unless you are experienced at testing voltages and taking printers apart.
Hope this helps, please take a moment to rate this solution.
Service ink reset error epson R265
Try to find out how to completely reset your machine through your manufacturer
Epson stylus photo rx 510 - turn on, wont do anything says error then scrolls scanner error
i have a epson stylus photo RX510 wont install into my computer with out the cd any ideas how to fix this
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
