There may be various reasons for your problem.
The SIM card might be damaged. Try inserting the same SIM card into any other active unlocked cell phone. If it works fine then there is no problem with your SIM card. If it doesn't work on other phone too, call the network provider for a replacement SIM.
The SIM port on your phone might be damaged. Try inserting any other active SIM card of same network on your phone, if it works fine, then there is not problem with the SIM port. if it doesn't work with it, take your phone to local mobile phone service.
Your cell phone might be network locked. If you have removed your old SIM card and inserted a new SIM card from any other network, your device must be network restricted to the previous network. You need to unlock it using unique unlock code. You can get the unique unlock code for a HTC Wildfire S from TheUnlockArena.com at affordable cost with an easy unlocking guide. Good luck.
Try the SIM card in a friend's phone.
Try a friend's SIM card in your phone.
1. Power on your HTC mobile phone with an unaccepted SIM card in (or no SIM card at all).
2. Enter your 8-digit unlock code you attained earlier.
3. Your HTC mobile phone should be unlocked and may automatically reboot!
These free unlock instructions provided above only work with GSM or SIM card versions of the HTC Wildfire.
I think helps.Let me know
Chandrashekhar
