How Can I Reset my TV.Menu Keep Popping Up and Turn On By It Self.
SOURCE: Menu
Is this a plasma TV ? If so remove the back cover of tv and unplug the cable that plugs into the IR board from the SSB that receives the signal from the remote. If it stops you panel is causing interference with the signal. If it doesn't your problem is in you SSB. you might see if there is a software upgrade offered by the producer of that TV.
