Depends on the vehicle... If the pulley is in the pillar of the car..you may be able to unjam it by slightly pulling and releasing several times. If it is really jammed ,the belt is probably caught or twisted in the pulley . You man have to remove the covering on the pulley disengage the inertia teeth to release the belt. If the car is real real old the works can get gummed up. In that case spray a little alcohol into the mechanism and see if it will release. Do not use any spray like wd40 ,cause it can get on the belt and ruin it's integrity, Good Luck!
