I bought as a scratch and dent at liquidation and the back page is ripped and can't see the factory code to open.
You must call (800) 828-1438 for combination retreivals.
If you need your combination, you must send a notarized letter stating you are the owner of the safe. (Note: the owner\'s last name must be different from that of the notary public). For locations that require a raised notary seal, use a pencil to shade the seal to insure that it is visible.
The notarized letter needs to include:
Keys Sentry Safe Replacement KeysLost Combination My Sentry Safe Combination Sentry Safe Shop Keys Sentry Safe Replacement Keys Lost Combination My Sentry Safe Combination Sentry Safe Shop
If you also need a key for your safe, you can order them online:
REFERENCE THE ACTUAL KEY LOCK (WHERE THE KEY IS INSERTED) FOR SMALL SAFES AND CHESTS
For Personal, Home and Home/Office Safes: (Model numbers will begin with: S0 (S0310, S0400, S0407, S0408, S0409, S0410), S3 (S3300, S3310, S3401, S3410, S3417, S3421, S3460, S3467, S3470, S3710, S3807, S3870, S3877, S3910), S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, CS, CSW (CSW3460), DA (DA3831, DA3930), DS (DS3410, DS3431, DSW5781), KSW, MS, MSW, OA (OA3810, OA3821, OA5848), OS (OS0407, OS0410, OS0810, OS3407, OS3421, OS3470), SC, and X (X031, X075, X105, X125)): Indicate your model number and the safe serial number is found on the front right-hand side of the door, between the hinges.
SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button. The safe opened. The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe. Wrong! Do it my way should this problem happen to you.
