SOURCE: Beko Freestanding Dishwasher
Hi there ....this condition is ususally caused by a water leak into the sump of the dishwasher which activates a safety switch to run the drain pump..preventing the appliance from being used....Remedy...tip the dishwasher back in the head allowing excess water to exit from the sump...then with the door open check that the air vent lock ring is secure, thet the salt unit retaining ring is secure..and finally that the filter unit to base screws are secure...this done re-start and you should b fine
SOURCE: No water running to dishwasher
I had this problem and almost tossed this thing out the window. The water stopped pumping into the washer but the cycles kept on going... HERES HOW YOU FIX IT!! In the front bottom right you see the mushroom shaped float..... on the underside of the dishwasher you see that is pushing down on a switch. Its a simple little switch but the plastic pin connected to the float is easy to knock off the switch witch always leaves it in the up position !!! this is telling the washing machine that it is full of water. Find a way to keep the plastic pin on top of the metal switch and this will fix your problem. I used tape with a small piece of paper to keep from sticking to the pine or switch!!
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
SOURCE: Hi, my zanussi zdf221 dishwasher wont work, it
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
