20 Most Recent Zanussi 24 in. DE6850 Free-standing Dishwasher Questions & Answers
Thermostat should be in the base of the dishwasher next to the heater element and looks like this part.
http://www.espares.co.uk/product/es567728/dishwasher-temperature-sensor?PartTypeId=1532&ModelId=576996
Zanussi 24 in.... | Answered on Apr 19, 2014
replace the heating rod that surrounds the pump base drain
Zanussi 24 in.... | Answered on Nov 18, 2013
is your water heater set on 120 degres
Zanussi 24 in.... | Answered on Jun 19, 2013
Make sure you unplug before you start. I had the same problem with a DE6850. The heater was ok. Metered at 25.ohms. Apparently, the relay on the control board mounted in the front door behind the switches is a common fault. Remove the screws around the top part of the door and you will be able to get at the control module. Resolder the connection. Zanussi reliability has been lost. Noel P31bf5e2.jpg
Zanussi 24 in.... | Answered on Mar 01, 2012
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Zanussi 24 in.... | Answered on Jun 12, 2011
remove RHS panel and you will see it bottom right. looks like a round cylinder with wires going into it.
if not heating worth looking at main board as wel for a broken solder joint on heater relay. bit of solder will sort this
Zanussi 24 in.... | Answered on Oct 19, 2010
Check your heating element..
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Zanussi 24 in.... | Answered on Sep 18, 2010
I've just had similar - seems to be a problem in the controller module - they're reasonably inexpensive online.
Undo the top-part of the door, about 5 screws across the top and side - the top section pops out, and the control module is now on the inside - if you free off the connectors (not too simple, but doable) you'll probably find some scorch marks on the PCB ... hopefully the wiring isn't damaged, and you can just replace the PCB ...
If you also have wiring damage, well, trace back and replace as required
(probably too late for the OP, but worth recording in any case)
Zanussi 24 in.... | Answered on Aug 28, 2010
Hi
Thanks for using FixYa. You’ll need to check the following things--
1. Fuse (blown or tripped).
2. Check the wire fasteners at dishwasher junction box.
3. Electronic control board.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate when START or OPTIONS is depressed.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Zanussi 24 in.... | Answered on Jul 20, 2010
Zanussi 24 in. DE6850 Free-standing Dishwasher Logo
54 questions posted
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Dishwashers
  • Zanussi Dishwashers
Most Popular Question
heating element zanussi de6850
  • Dishwashers
