REbuilt Transmission for Ford should be At MAX $3.000. And add another $500 for the 6 Hours it should take to install "Ford Time"...
OR go to a normal Trans shop and pay $2000 or less and that Should include the Install.. However What is the Trans Actually Doing? Is the Overdrive light Flashing?? AS for the Axle, Autozone wants under $100 for the Axle And if You want NEW I'm sure I could get it for you for less then 500 and the install for most people are around $150.00 ...
You are being Taking for a Long Hard ride.. Don't do it.. :) Find someone else for Proper Costs...
Don't go to ford dealer ship.they are very expensive.Do you have wrecking yards in your area take a visit there for a used transmission.I'm sure it will be a lot cheaper than what you have been quoted.Also have a local mechanic to do the fittings for you.by doing the shoping your self you will save a lot of money.Ebay has answers for you,do some research.....
Testimonial: "I called the junk yard and they have a mechanic who charges $900 for the transmission and $600 for labor. I am thinking about trading it or just get another van."
SOURCE: trans slip when pulling toy hauler
Heat is killing your transmission. Change the transmission oil and filter and slow down. Pulling something that heavy is best with a manual transmission.
SOURCE: 95 oldsmobile cutlass ciera leaking transmission fluid around the oil pan
Have the car put up on a lift, or over a pit for inspection.
I went to the junk yard, they have a mechanic. The mechanic told me $900 for the transmission and $600 for labor. Ford never gave me the codes from the diagnostic testing they did, I didn't have any light on before Ford worked on it. I'm stumped! I am going to look for another vehicle because I am scared of putting a new transmission in and then something happens to the engine.
