I'm having the same issue on my un55es6500, it just started about an hour ago. I stepped out of the room and when I returned it was there. I currently have it on the floor (carpeted) due to staying with family, before that it was mounted and never had any issues, what can I do to fix this issue?I'm having the same issue on my un55es6500, it just started about an hour ago. I stepped out of the room and when I returned it was there. I currently have it on the floor (carpeted) due to staying with family, before that it was mounted and never had any issues, what can I do to fix this issue?
You can't post conmments that contain an email address.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Can be the back light led or the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
could be as simple as a bad HDMI cable or a bad connection on the LCD screen to system board cable this is internal so harder to repair. It may be a bad LCD screen, which is not really repairable as spares are hard to find (no two alike) and expensive as a new TV.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
