It plays cd normally from first to last song. but when we try the next song it keeps loading and no play. finally we have to reinsert the disk and then play.
That is not the player... to solve this problem, you need to re-install firmware, what you described it suggest that your firmware is corrupted.
as you did not supply manufacturer, model and version - and for some reason telepathy did not work today on me very well... go to the manufacturers site and read and create firmware update/restore disk/usb whatever manufacturer will recommend, do procedure as per instruction and you should solve your problem.
again - for future reference, always describe the problem (this bit you done perfectly), then manufacturer, operating system if required, model, version - all that data help to solve the problem.
hope this short info will help you
