I found problem in ATX power supply and replaced with a new one.But still the motherboard not responding, even the ATX 20 pin connector fixed and stable supply of 5V is OK. I also noticed that the green LED in the mother board not lighting up.
Please help me.
Note: the Mother board is Asus 945G
Mohandass, Coimbatore, INDIA
If the power supply had a problem then it is likely that the motherboard and/or the CPU got damage from that. I would check the 12V and the 3.3V lines from the PSU.
Without more information I cannot say specifically what the problem is. You can try disconnecting everything from the motherboard except video card, CPU, and RAM to see if it would work that way. If it does then you can start connecting devices until it does not work any more then you have found the problem. If that does not work at all then unplug the video card and RAM see if anything changes (you should get a beep code without the video or RAM). If nothing changes then either the CPU or motherboard is bad and the only way that I know of to find out which one is to either try the CPU in another motherboard or try a different CPU in that motherboard.
Hi
My motherboard also don't turn on. I tested the ATX ower supply and it is OK. After I jumped the pin # 16 to Ground and conect the power supply cable, the PC turn on, so now I would like to receive a help how Can I fix the motherboard?
Thanks
