Generally, the L5 error indicates that the controller circuit is not receiving any data feed from the speed sensor of your treadmill.
When you start the treadmill (that has a L5 error), it will start briefly and then stop. It stops due to a built-in safety feature i.e. no speed data = stop motor.
To fix this issue:
Remove the motor cover, the speed sensor is located near the small wheel that has the small belt that connects with the roller. The sensor is a little (usually black) tube like thing.
In 90% of the cases, the sensor position has shifted (usually happens if you're not too careful when removing or fitting the motor cover). The sensor position is sensitive with respect to the two magnets embedded amongst the spokes of the small wheel (see photo).
In some treadmills, the sensor is fitted parallel to the wheel while in others, it is fitted perpendicular to the wheel.
All you have to do is move the sensor a tiny bit to the front (or back) and restart the treadmill. If this did not work try to reposition again (see attached photo). Depending on how far the sensor shifted from its correct position, it might take a few tries before you get it right. You know you've got it right when the treadmill once again functions normally.
In 10% of the cases, the sensor wire might have either got disconnected or broken (usually happens if you're not too careful when removing or fitting the motor cover). If you are a DIY kind of person and have a soldering kit handy, then you will know what to do else, call the technician - shouldn't take more than 15 minutes to fix it.
Hope this helped.
SOURCE: treadmill shuts off in about 60 seconds.
try calling the techinal number tell them the problem and they should be able to help u
SOURCE: i have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
SOURCE: error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
SOURCE: new free spirit treadmill - L5 code what does it mean?
Yeah - the sensor is the problem... It is magnetic... You can find it next to the wheel on the belt - It is fairly small.... There is a metal disc in the wheell on the belt that is a magnet.. As it passes by the sensor - the sensor registers the magnet and can simply calculate speed based on the frequency of the passes... Sometimes the sensor slides too far back and ergo can`t register the magnet passing by - Then you get the L5 error...
Follow this link to a picture!
http://www.angelfire.com/nm/nickm/freespiritl5.html
