Televison & Video Logo
e
ed Seeger Posted on Jan 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you connect Samsung sound bar to my Sanyo dp52440A. TV has no receptacle which fits the audio aux which came with the sound bar
Sanyo serial #RO48ML55105845 Chassi # DP52440A
Mikey
Level 3:
Top Expert:
  • Sanyo Master 6,904 Answers
  • Posted on Jan 01, 2015
 Mikey
Sanyo Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1623621
Points
26106
You don't have an optical digital connection on your TV but you do have a coaxial digital audio output that you can connect to the aux in on the soundbar!
Connecting samsung sound bar to sanyo fvm3982 tv
Here are steps to connect a Samsung soundbar to a Sanyo FVM3982 TV using an optical cable:
  1. Locate the Optical Out port on the back of the Sanyo TV. This port will be labeled "Optical Out" and is usually covered by a small protective cap.
  2. Remove the protective cap from the Optical Out port and plug in one end of the optical cable.
  3. Connect the other end of the optical cable to the Optical In port on the Samsung soundbar. This port may be labeled "Optical In" or "Toslink".
  4. Turn on both the TV and the soundbar.
  5. On the Sanyo TV, use the remote to navigate to the audio settings. Look for an option to set the audio output to "External Speakers", "External Audio", or "Optical Out". Select this option.
  6. Adjust the volume on the Samsung soundbar using its remote control.
Once these steps are completed, the sound from the TV should be played through the Samsung soundbar. If you encounter any issues or don't hear any sound, check to make sure that the soundbar is set to the correct input and that the volume is turned up. Additionally, make sure that both the TV and soundbar are properly connected and powered on.
My Samsung tv model number UA40C5000QF does not have a hmdi arc port and we have bought a Samsung sound bar but it cannot be connected as it does not have that port
Your sound bar can be connected to the UA40C500QF. Get an appropriate audio cable based on the sound bar. You'll either need a optical digital audio cable or an analog audio cable with a 3.5 mm plug on at least one side. (If your sound bar has an AUX input, then a 3.5 mm to 3.5 mm M/M audio cable is appropriate. Otherwise, you may need an RCA (M/M) to 3.5 mm audio cable or some sort of RCA to 3.5 mm adapter (F on one side, M on the other).) Connect this cable to the audio out on the TV (headphone or digital audio) and the appropriate audio in on the sound bar.
Set the sound bar source to the chosen input (Aux or Digital In (D.In on some systems). Next, set the TV to use External speakers. This is in the Audio sub-menu. The volume will now be controlled by the sound bar volume control.
You can still use the HDMI cable (HDMI out to any HDMI in on the TV) if you want to use the TV screen when changing the settings on the sound bar. Just change the TV source to that HDMI port with the Source button on the TV remote or on the TV (the left-most button on the front panel). Then change your source back to the video signal for the TV to view items connected to the other HDMI ports. If your sound bar has an HDMI input, you would similarly use set the TV to the sound input to watch that source.
I hope this helps. See the manual for the UA40C500Q for the details on setting the speakers to External speakers. The manual is available on the support page: https://www.samsung.com/au/support/model/UA40C5000QFXXY/ . The current link to the manual is http://downloadcenter.samsung.com/content/UM/201003/20100316163048500/BN68-02727A-00Eng-0225.pdf .
I have just bought a samsung soundbar hw h355 and I'm trying to connect it up to my toshiba tv, via the aux cable but I get no sound from it via the tv link. I works when I link my phone up via Bluetooth....
Please get a optical cable and run it from TV to soundbar for best sound. If you are using aux input on sound bar that will work but it is analog sound. TV needs to have mini audio out or red/white output on it maybe labeled audio out
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
1helpful
How do I connect Samsung soundbar 550 to sanyo dp55441?
Use the audio out ports on the Sanyo to get audio to the Soundbar. You can use a single digital audio cable or the legacy RCA audio cables. The Audio Out ports are marked in white on the back of the TV. If it doesn't work, turn off the TV Speakers in the TV's menu.
How do you connect Samsung sound bar to my Sanyo dp52440A. TV has no no outlet which fits audio aux which came with my Sanyo TV
Hook your sound bar to your output device, Cable Box, DVD/Blu-Ray player. Or try the follow should your Sound Bar have HDMI.
Output Device>Sound Bar>TV
The Sound bar should have a HDMI in and out or at least most Samsung models do as well as Bluetooth support.
It is easier to answer when you list the model of each Item, there are many different version of Samsung sound bars.
Just purchased a Goodman 50 w sound bar connected to AUX on tv and sound bar clicked AUX on remote white light shows no sound just a loud buzz
To the best of my understanding an Aux port is usually an input port. So you might be sticking the sound bar terminals into the wrong connector in TV. The audio signal from the TV is meant to go into the Aux In port of the sound bar. Usually this will mean a pair of RCA cables (white and red) from TV out to Aux In. If you have done the right things then maybe check if soundbar is not in mute. Try some other source as well. Like connecting an iPhone or ipod stereo out to the Line In port in soundbar and selecting LineIn mode.
see page 7 in the soundbar manual. It is hard to know what TV connection you are using. Is it selected on the TV settings? http://www.goodmans.co.uk/support/downloads/user-guides/GDSB02BT20-ib.pdf
I cant get any tv audio on my samsung ht-z310.
Red and White cable wires are usually for Audio wires. Make sure yo connect it to either Audio (Red & White) Out or Aux Out in your TV and connect it to your Audio (Red & White) In or Aux In in your Sound System/ Home theater.
2answers
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
