their should be a safty wire run to the emergency brake that allows video only when the brake is set to bypass it you would need a relay wich you can get at autoparts store check out youtube for video on how to wire the relay
the parking brake wire must be connected to the parking brake system of you car. When the parking brake is engages, the LCD will be allowed to view your video. If not, the screen will produce an image saying, parking brake. this is a feature designed for the driver not to watch a video while driving. The video output on this unit will not be affected by this, el wire to connect is Pink - parking brake. this is wire connect with ground.
I do not know this specific unit, but it sounds like a safety device built into the unit so you cant watch the screen whilst driving.. it may be that you have ommitted a sensor wire or got a sensor wire reversed.
Re-check all your wiring and make sure that the ignition live and the battery live wires have not been reversed...
This unit was not designed to be used while the car is in motion. Your parking brake must be in the engaged position in order to view the monitor. The brake wire must be hooked up to the parking brake wire or grounded in order for this function to work properly.
The problem is that you're trying to bypass a safety feature. Newer video head units are smart enough to know when you've just grounded the brake switch wire so you can watch it while you're driving. Try hooking it up to your parking brake wire.
