SOURCE: black and white playback on television screne
Select the correct color system in your tv. probably the system which was selected in your tv did not match that of your video cam. good luck!
SOURCE: Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
SOURCE: Rolling of picture
It seems your Handycam has " Pal " system and you are watching it on " NTSC " TV. If your TV is Multi Color System, please select Pal color system. Hope this info will be helpful for you.
SOURCE: Record off the tv.
Hi there and welcome to FixYa.
Hmmm. Ok, I need to know a few things. Does your TV have an RF out jack? Do you have a VCR? And last but not least...does your Jazzy have an RCA type video input jack?
Let me know and depending on your answers, I have a workaround you can use.
Rob
SOURCE: The tape plays back in
What is model number of Sony camcorder? Question shows it is DCR-TRV330, please confirm.
As you said, camcorder shows color picture in its lcd monitor but gives
black and white output at AV output for tv connection, when did this
problem occurred? any idea?
Thanks.
