Either the dial is stuck (won't move past setting "4") or I don't understand my machine. Can't get to the stretch stitches.
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Never mind - I finally found it - Thanks anyway.
