Precor C966i Commercial Treadmill Used Logo
Cleve Gardner Posted on Dec 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find a used lift motor for a Precor C966I treadmill? Part # on the motor is 6182A-1705080-01
Sportsmith LLC
Level 3:
  • Precor Master 920 Answers
  • Posted on Nov 13, 2015
Sportsmith LLC
Precor Master
Level 3:
Answers
920
Questions
0
Helped
514927
Points
111994
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I am not sure where you can find a used one, but I can find a couple of new options for you. Depending on your machine, there are two different motors available. One is for a 220V machine and the other is for 110V machine. I will post links to both.
MOTOR LIFT ACTUATOR 120V PRECOR TREADMILL PPP000000044257107 SPORTSMITH net
Lift Motor 240V Precor PPP000000044257108 SPORTSMITH net
3 Related Answers
Anonymous
  • 15 Answers
  • Posted on Jul 09, 2010
SOURCE: Just moved my precor c966i treadmill (we
it should be a cable that looks like an oversized telephone cable. I can't really tell by the description of the problem if you just can't remember where it plugs into or if you've lost it altogether. There will be a circuit board in the base of the treadmill that will have something that looks like a phone jack port on it. That's where it will plug into. There should only be one port on the lower board that will accept that style of plug.
Testimonial: "This is the exact answer to the problem--after much searching around, I finally found the little box it fit into. the treadmill is up and running. Thanks for your input."
Anonymous
  • Posted on Mar 06, 2011
SOURCE: The belt on my Precor
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
Joshua
  • 95 Answers
  • Posted on Jan 13, 2012
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
Error 22 comes up on my Precor Treadmill C966i what can I do about this ?
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
https://www.sportsrec.com/reset-error-code-precor-treadmill-5519820.html
https://www.youtube.com/watch?v=_yD5eoMNB64
We only get a STOP KEY and it will not run
c966 have Precor transported from one place to another place is not rash to give any signal in transcri could you help
Precor error 15 input voltage
Precor Error 15, AC Input Voltage Too High Probable Cause 1. AC input voltage is incorrect.
2. AC input voltage transients. Transients can be caused by lightning strikes or by other pieces of equipment sharing the unit's AC power.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. Ensure the AC grounding for the unit's outlet is good and verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error Code 15
We also have a precor c966 it stops sporadically. We have already had it serviced and put a new belt on it and the problem continues.
see the video and lube the deck belt+rollers bearing too.
Tight the drive belt motor.
test the motor see the diagram and go to my personal tips for motor helps.
Speed sensor of DC Motor treadmill making noise.
the speed sensor NOT make noise, is the main motor see the diagram attached.However tight any connector or plug very well, and test the s. sensor for open or defective and replace. You can RUN the software calibration for easy diagnose, troubleshooting, and fix it.
You must test the input voltage motor, if there are the motor need repair, bearing, shaft, or winding defective.
God bless you
Error 32
LUBE OR wax you deck belt, this happen for autoprotection electronic system. To due a lack of LUBE maintenance schedule.Do it right now according with owner manual.
2)lube THE rollers bearings too use WD-40 for the bearings only
3) Test the drive belt motor, for cracking or worn belt, replace or adjust in according.
4) Test the motor voltage input, if there are the motor need repair, see my personal TIPS for troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Precor C966i The unit turns off at random intervals. When reset it comes back on then shuts off a few minutes later. Error log is empty so not an error with software.
LUBE or wax the deck belt, this happen because you do not lube or wax your equipmente according with the schedule maintenance, you must do it, every week. Do it now.use 100% silicone lube-
2) LUBE the rollers bearing too use WD-40 for rollers b only.
3) Test the drive belt motor, and adjust it or replace
4) test the input voltage motor, if there are the motor need repair.see my personal TIPS for troubleshooting helps.
5) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
1helpful
The belt on my Precor C966i treadmill is not running and the display is flashing an "Error 22" message - what's the problem?
1helpful
Just moved my precor c966i treadmill (we disassembled it down to the motor/treadmill part) and can't remember where the gray snap-in electronic connector that runs from the console down to the motor and...
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
