SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Unscrew the crown pull out the crown to the first position, One click and rotate the crown clockwise. This is for Quick Set models
For non quickset
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
SOURCE: does anyone have a manual for a datejust rolex
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in date setting position,
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
SOURCE: how to change bezel on Rolex Datejust
The bezel is secured by a Teflon gasket. To remove the bezel I would use a watch knife and gently press it in between the bezel and the case. Make sure you go straight in and it might not be a bad idea to use a layer of plastic around the knife so it doesn't leave marks. Also, do not use a widling motion. GO STRAIGHT IN. This will also prevent damage to the case and bezel. Repeat this several times working your way around the bezel. Be sure you don't continue to apply pressure with the knife once the bezel begins to come up as you don't want to damage the Teflon seal. Once you have the bezel out you will need to replace the Teflon seal the exact same way it came off on your replacement bezel and press back into place.
SOURCE: How do you open the latch on a Rolex datejust
If I understand right, by the latch you mean bracelet clasp. You just pull it by the crown. Clasps on ROLEX watches can be very tight, so, have to pull it with appropriate force. Rate me, plz.
