Elevation coffeemaker
I have the exact same problem, but would also like a new single dose dispenser, as mine is a littel clogged after so many years impeccable use. The model number is
376D3320
Pump Espresso Coffee Maker
Any help would be very gratefully received.
ERROR
CODE # 7
E7-
1) Alternative Elevation Motor
1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection
2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate
3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation
4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet
c)
Cause:
Line
Cord Damaged Solution:
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
Plug
c)
Cause:
Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
ERROR
CODE # 7
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
Plug
c)
Cause:
Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
see the block diagram+additional diagrams for troubleshooting and fix it.
God bless you
see the 2 alternatives. and proceed for fix it. God bless you
ERROR
CODE # 7
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
Plug
c)
Cause:
Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
ERROR
CODE # 7
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
Plug
c)
Cause:
Line
Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Doesn't Light Up: a)Cause:
Plug
c)
Cause: Line
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
God bless you
ERROR
CODE # 7
E7-
1)Cause:
2)Cause:
3)Cause:
4)Cause:
2)Alternative:
Display
Plug
c)
Cause: Line
Replace Line Cord
After extensive research for the same thing, I have found out that the Elevation is actually a Breville Modena so look for that or the Breville Roma Cafe, both are the same part numbers and are pretty widely available, even direct fro Breville of you live in the USA or Canada. For some reason the rest of the world don't count and they won't ship to us :(
Sorry I should have said, if the machine has a Woolworth's sticker on the back and looks like the one in my picture. Also, depending on which site you buy from they are called a group seal, or steam seal and are 50mm in size. Be careful to check the size as some are 58mm and no good. Hope this helps.
