SOURCE: Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
SOURCE: Jabra BT8040 is not pairing
Make sure the headset is off. iPhone--Settings--Bluetooth---On---Press and hold the answer/end button for approx 5 secs until lite turns sold blue. It works
SOURCE: jabra bt8040 is not pairing with iPhone 3gs
No problem. When Jabra is off, press and hold till green light turns blue. On the iPhone: settings, general, bluetooth; switch to on. It will search, then it will list the Jabra BT8040, not paired. Highlight the "not paired" line, and it will start to pair; a few seconds later, it will say "connected".
SOURCE: Jabra BT135 won't pair with my Iphone -
take the Bluetooth device and keep its button pressed till the light stables that is u will have to hold the button for more then 10 seconds!!! then once the light is stable keep it like that and take the phone and search for Bluetooth devices it will find it now and then enter the pin given in the manual or mostly it is 0000 and pair the two devices now u are ready to use it!
enjoy!
reply and rate!!
Testimonial: "Wow - what a fast answer! Really much appreciated, thank you. I did just as you said and got my bluetooth headset connected straightaway. Once again - thanks for the superfast response"
SOURCE: I purchased a new Iphone and my Jabra will not
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time
you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
