Model C122, it was purchased on July 5, 2013. Has been working fine until the bottom drawer was left ajar.
Hello Omie;
My name is Peter. I am a retired field service refrigeration technician.
Bottom drawer & bottom freezers are nightmares. Next time but a side by side or top freezer.
Ok, lets fix this. Using a hair dryer defrost all of the ice around the door. Next, you have a rack and pinion assembly that the drawer rides on. This also is iced up. Defrost the rack & pinion.
When you close the drawer you will probably have a gap on one side. This is caused from the ice build up and the rack and pinion jumping a tooth.
Where the side is that has the gap, you must lift the drawer and jerk hard towards the gap to jump a rack and pinion on the opposite side. You may have to repeat this. It is a strong arm operation.
SOURCE: tempature on fridge won't stay @ 38
might be freezing on the evaporator faulty defrost timer or drain is blocked water should run down back bottom tray
SOURCE: refrigerator indicator lights read off and cannot be turned on by up and down arrows
hi there,
you have a problem with either the keypad or the control board. have you checked either one yet?
