Archos ARNOVA 10 Android Tablet Logo
J
John Neary Posted on Oct 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Abdroid 4.2.2 The tablet screen display has turned insideout How do I reset back to normal?
I downloaded some apps and then turned off When turned on again display was reversed Mirror image. I have done a factory reset and removed all the apps but no change. How can I cure?
Alisha Bunting
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Oct 25, 2014
Alisha Bunting
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
443
Points
12
Here's a link to what worked for me (4.0.3 through 4.2.2).
honeycomb emulator reversed screen in portrait
Here's the important part
"sroll down to screen orientation and select sensorPortait in the drop-down menu".
Note: you'll probably need to do this for each activity if you're launching them in a stack. You can just copy/paste in the manifest file after you've done the first one.
Testimonial: "can't find screen orientation on this tablet"
Mikey
Level 3:
Top Expert:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Archos Master 6,904 Answers
 Mikey
Archos Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1623663
Points
26106
Factory reset deletes everything and takes the tablet back to when new.....so how did you do a factory reset?
  • John Neary
    John Neary Oct 26, 2014
    personal/backup& reset/factory data reset
  •  Mikey
    Mikey Oct 26, 2014
    Did you lose any data or apps or anything downloaded from new when you did the factory reset?
1 Related Answer
TechyDrood
Justin
  • 2072 Answers
  • Posted on Nov 27, 2012
SOURCE: want to reset to factory settings
This option will typically be under
Settings > Storage > Factory Reset
2answers
How do i factory reset my verizon samsung 10 tablet?
To help you perform a factory reset if your Samsung tablet is working and powered ON, please follow the instructions mentioned below:
- It is recommended to back up all the data like Phone contacts, Email accounts, App settings and Downloaded apps, Music-Picture-Videos, Internet browsing data and Personal data from the tablet before performing factory reset.
- From the Home screen, navigate: Apps > Settings > Privacy.
- Click on 'Factory data reset'.
- Click on 'Reset tablet'.
- Click on 'Erase everything'.
- Allow several minutes for the factory data reset and reboot processes to complete.
Now, if in case you need to perform a factory reset if your Samsung tablet is powered OFF, please follow the instructions mentioned below:
- Press and hold the 'Volume Up button' and then briefly press the 'Power button' to power on the device.
- Release the 'Volume Up button' and the 'Power button' when the Samsung logo displays on the screen.
- Use the 'Volume Up button' to select the 'small android with an arrow' icon.
- Press the 'Volume down button'.
- From the Recovery Console screen, use the 'Volume button' to select 'Wipe Data / Factory Reset' then press the 'Power button'.
- Use the 'Volume button' to select 'Yes' then press the 'Power button'.
- Once the Wipe Data / Factory Reset has completed, use the 'Volume button' to select 'Reboot System Now' then press the 'Power button'.
GuruAid.com
When i turn it on i get a message that says unfortunately,launcher has stoped wont let me do anything else
You need to do a FULL reset.
1. Power off unit
2. Hold down POWER and Vol - (or Vol+ if Vol - doesn't work) until Android reset screen appears.
3. Scroll down to factory reset and select it.
4. Agree to reset
Unit will reset itself and start over like it was brand new and you will lose everything that was installed. Most likely you have a corrupt operating system and this may help. However, many android apps will not work on that tablet as its an older tablet that does not have an upgraded OS available.
Good luck
1helpful
2answers
How do I unfreeze a Google app page?
Reset the App
1. Double-click the Home button. This minimizes the app and displays the iPad's multitasking screen.
2. Drag the stuck app upwards on the screen. This forces the app to close and removes it from the iPad's memory.
3. Press the Home button to display the iPad's home screen. Tap the app's icon to relaunch it. Any unsaved data, like words you typed in a document or progress in a game, is lost, but the app opens and should respond normally.
Get a full screen on face book please
Suggest to first try logging into Facebook using the browser on your tablet instead of the facebook app. If that display is normal in size ... it's probably easiest to
(1) uninstall the Facebook App (Control/Settings/Apps);
(2) reboot the Tablet;
(3) Restart the Tablet and Go to the Google Playstore ...reinstall the Facebook app.
1helpful
4answers
1helpful
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
3helpful
Locked out of my tablet by my child entering a new pass word...
To unlock your tablet, you will have to perform a factory/hard reset of the device.
Performing a hard reset will DELETE ALL DATA from internal device storage and reset the tablet back to the state before you turned on the device for the first time. Resetting the tablet does not erase any system software updates you have downloaded or any files on your SD memory card, such as music or photos.
To perform factory/hard reset please follow those steps:
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
* Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
* Allow several minutes for the reboot process to complete.
Top Archos Tablets & eReaders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
