Tag Heuer Carrera Calibra S
Https://www.watchuseek.com/threads/help-me-set-the-time-on-my-carrera-calibre-s-laptimer-cv7a11.275908 /
Very good video of this on youtube.
http://www.youtube.com/watch?v=EQJUl64EMIE.
Good luck, as the guy on the video says it is complicated!
SOURCE: TAG Heuer Carrera Calibre 16
Hi
This is a warranty issue, the watch should not lose time like this. Take it back to the supplier ASAP
Cheers
Dave
SOURCE: I have a TAG HEUER Grand Carrera and the second has stopped
Are you aware that these are automatic watches and need to be moved to keep the watch going, kinetic energy winds up the movement which allows it to keep going, if it is left off your wrist and in a drawer or sat stationary it will stop. Shake it violently (without dropping it) and it will restart.
SOURCE: Owners Manual for Tag Heuer Carrera Twin Time Watch
you can find an exper in the local shop where you buy the product and
they will give you specific service for your questions about your
product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to buy world of warcraft gold with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service when your login.
SOURCE: looking for an owners manual for my Tag Heuer
Go to the TAG web site ( insert "www.tagheuer.com/the-collection/" into your search engine).
Select "Carrera"
Select "men" or "women" as appropriate.
Select the model of the Carrera you have.
On the right of the screen you will see a list of options, select "user manual"
Adjust the magnification to make the text readable.
SOURCE: Tag Heuer Carrera CV2A10 date display changes at 3AM??
Unfortunately, there is not much you can do with this, as for fixing it you need very experienced watch repairers help. All I can do is just name all possible reasons why it happened. FIRST reason could be: the day wheel somehow has lifted and not sitting in correct position. This would be the easiest fault for watchmaker to repair, as only dismantling the movement, correcting the day wheel and re-assembling will be necessary, so, no serious repairs needed. SECOND reason can be: the star, which is friction fitted to the day wheel is getting loose. In this case, if watchmaker will not be able to fix the day wheel, you will have to buy new day wheel + all work previously explained. THIRD reason: the day wheel click spring is weak/bent/broke. In this case you have to buy new day wheel click spring + again all the work previously explained. FOURTH and last reason: day wheel positioning screws/borders became loose. In this case only the work explained in FIRST reason will be necessary. If you are so lucky and still have warranty for your watch - send it back to Tag Heuer and they will do repairs without charge, because this fault is covered by warranty. If warranty has expired, you do not need to find any particular Tag Heuer watch repair shop. As all watch movements are manufactured on identical basic principles, any reputable/decent watchmaker will do the job for you. Prepare yourself to pay quite a lot, because Tags are expensive to deal with and takes a lot of time and skill to fix. This is all help I can give. Wish you luck. Rate me, please, and/or write some testimonial if you have spare minute.
Testimonial: "Thank U so much for the enlightenment, escapement. Your points really do ease me alot. Will go to retailer/svc shops and we'll see from there. Cheers!"
