It would be helpful for someone to help you if you shared the exact model of the scanner. Most scanners and radios have a squelch knob. Squelch is basically the static you're probably talking about. Again depending on what scanner it is exactly unplugging it may or may not have deleted the programming and settings if it's programmable. If it's not programmable unplugging it definitely did not clear any memory, settings, or programming. I'm guessing it was also moved and someone turned the squelch knob either accidentally or messing with it. Find and turn the squelch knob if it has one until the static goes away and it should start scanning again.
Check to see if you have a beep (roger) setting turned on. Other than that, it may be something in the switching circuitry that is causing this. Are any of the other radios in you group the Baofeng GT-3? This is a real hard one to pin down without some hands on and test equipment.
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units.
first of all is it set up to a antenna source? if so then turn the squelch nob counter clockwise all the way, then turn the device on. next start at channel one and slowly turn the squelch clockwise until the pin moves or you hear static. then surf the channels adjusting the squelch to to that static point until you find your active station. from there to cancel static between transmissions turn the squelch so that it is just below the static marker.
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
We agree, it does take some patience to program this model of radio. However, it is do-able. You need to program both the Frequency and the Code. If you set your code (the smaller number), it should eliminate interference from other users. If not, switch to a different set of numbers until you find a clear frequency in your area. Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXX_User_Manual_E.pdf
On the issue of static. Static is usally caused by using a bad, defective or poorly charged battery. This model of radio has not been offered for several years. It is likely you have batteries which need replaced. Your local Motorola dealer should be able to get the batteries for you. Or purchase from an online Motorola vendor.
I posted a solution under a different problem, but similar. Basically you will need to pick a static IP for your xbox. Then set that IP address in the router web config >> routing >> DMZ IP address setting. Restart both router and xbox and bingo. Your xbox is now directly connected to your cable modem without the router problems preventing connectivity.
I have T5720s - both have the same settings (channel 1), both are charged, but they won't communicate. They beep when you push the "talk" button, but you don't hear anything on the second radio.
Check the squelch on your radio thats not recieving. If there is a monitor button ( when pushed you will hear static) try pushing it.. then get someone to call you so you can check if you can hear them.
On these radios you have 2 types of squelch....1 is called carrier squelch.... it basically opens when there is a strong enough signal. This lets you only hear strong signals and "squelch out" the distant ones and background static.
The2nd. is "tone squelch" ... with your radio they are often called privacy tones. If you have 2 radios set with the same privacy tones you will only be able to hear each other... only radios that are transmitting with that privacy tone will be heard on your radio. Its a high frequency tone that can't be hear by the human ear that gets "embeded" with the transmitting signal. The recieving radio hears it and opens the squelch.
So... if the radio thats rxing (recieving)your signal has its squelch set for just carrier squelch it will hear any signal thats strong enough to break the squech open.... basicaly any radio within a certain range. But if your radio (one with problem) has its squelch set for privacy tones you will not hear any other radios except the ones set with the same privacy tone.... the squelch will not open until it gets a tx signal with the right tone.... so if the txing (transmitting) radio is not using tone squelch but is using carrier squelch.... and the rxing radio is set for tone squelch... the rxing radio will not hear it.
With tone (privacy tones/codes) squelch you need a tone to open the squelch and then the audio can be heard... with carrier squelch the squelch will open if ANY radio is within a certain range.
Check the squelch setting on the problem radio... it could have a privacy tone set. Try pushing in the monitor button so you can hear static ( you want to hear everything including static) on both radios... tx on one radio at a time and listen if it can be heard on the other with the monitor button pushed.
If you can't hear any audio when the broken one is transmitting then it COULD be the mic.... if you can hear both radios with the monitor button activated than the radios are txing and have tx audio and are working... if thats the case its the privacy tones that are the problem.
Take care
Do you hear the Beeps on the speaker?
Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0".
Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
