The TV is not connecting to the wireless router
SOURCE: how to connect sound system to Hisense LCD tv
I phoned the help line at Hisense, they stepped through the set-up - its all good now
SOURCE: I connect my laptop (Dell
You have to tell the laptop to use either DUAL or EXTERNAL display.
This is usually done with the FN button pressed in conjunction with the F5 key (may be other key)
The F key you want will have a small monitor icon or even two overlapping monitor icons.
SOURCE: I have a hisense 50"
Hello dollfinn,
I'm going to need you to be a little more specific in your request. It is not possible to supply a manual without knowing the model number of the TV and I cannot tell you how or where to make connections without knowing what you are trying to connect.
Please could you provide as much detail as possible about your problem so that your question can be answered quickly and correctly. Please reply to me by clicking on "Add a Comment" below your question. The following details are essential:
1. Model number of TV
2. Brand and model numbers of devices you want to connect
3. Which cables you available for connecting the devices
Thanks,
BElectric
SOURCE: need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
