Ok I am having problems downloading kings games I have a tmobile samsung 2.2androied phone and every time I want to download your games this will pop up your device is not compadable with this version it also does that on all of the facebook games can you fix or help me I have played some of your games befor and I like them
Good day. Use card reader to transfer file from pc to your phone, or if you have a cable supported from your phone package you can use it, but make sure to download the software first to your pc, so you can able transfer files without getting off your memory card. Thanks.
GO TO GALLERY AND SELECT YOUR PHONE AND JAVA SOFTWARE CATEGERY.
DOWNLOAD AND INSTALL GAME YOU LIKE MOST.
FOR MOVIES YOU HAVE TO DOWNLOAD SMARTMOVIE PLAYER OR DIVX PLAYER TO RUN .AVI FORMAT ON YOUR DEVISE WHEN YOU HAVE DOWNLOADED THAT APPLICATION (USE MOBILE9) DOWNLOAD MOVIES FROM www.mobilemovies.net. ALWAYS USE FIXYA TO FIX YOUR PROBLEM.
you have two choices 1 is to download directly to cell if you have a data plan or not Tmobile will charge according to size and time to download the second is to download to pc then transfer to cell...here is a site you can try http://www.zedge.net/download/
You have downloaded the game that is not supported by your mobile. Thats why you are receiving this message . For example : Certain games can work in java interface , some works under different interface . Check before downloading whether that game is supported by your model. Don't download any game from free website . They can damage your phone .
maybe the games that you want to download is not applicable to your mobile.. every downloadable games has its own system or phone requirements like disk space.. choose the games that fit to your mobile
To Install Java Games On Your Samsung-E250,You Have To Download "Softick" PPP and A "Java game Uploader"(search it on Google)..........
lnstall java games using usb data cable SAMSUNG E250
Install\Run SoftickPPP221 from the Softick.PPP.v2.21 Folder. Ignore any errors about usbsync.dll by pressing OK.
Leave the option use usb in shared mode checked.
Run when finished installing. You will get an error message about being unable to locate usbport.dll, just click cancel.
Plug in your usb cable and turn phone on.
Right click on softickppp running in your taskbar and select settings.
In the usb tab uncheck accept ppp connection on usb and tick both use usb in exclusive mode and overide usb compatability,
Click on ok and completely exit softickppp by right clicking then exit.
Run softickppp and again goto settings. On the bluetooth\serial tab tick the correct com port.Mine is com3. Then click ok
On your phone key in *#52828378# press 2 ota type setting and select serial bearer ota.
Run samsung java uploader and add your jad file
On your phone select 3 serial test , 1 ppp up , 2 usb
Your phone will now reboot. While its rebooting right cklick on softickkppp in your taskbar and choose shutdown ppp
When your phone has rebooted again key in *#52828378#
Right click softickk ppp and activate ppp
On your phones java test menu press 3 serial test , 1 ppp up , 2 usb , 2 serial download
Your game should install and start running.
