I have a fold-up crosswalk treadmill. My problem is the belt tends to drift to one side or the other. I tried to correct the problem by adjusting the back roller. I'm not sure if I over-tighten therefore damaging the back roll. If this is the case where to I go to replace it?
Hi there ,
The problem wont be the roller . It will be the belt . Whilst the machine is in the upright position look at the material side of the belt and check for any loose material or wear patches. If this is found the belt needs to be changed . Definitely dont use the machine anymore. The other possible problem is the uneven adjustment of the rear roller causing the belt to run to one side. Home Treadmill Repairs Brisbane Brisbane Leading Treadmill and Fitness...
Your problem may be as simple as a loose walking belt. It could also be that the belt guides on the underside of the deck is too wide. Ir could also be that your rear roller collapsed (there should be noise in this case) or your rear roller screw is broken or not holding tension for some reason. Try adjusting the belt again. Consider that the belt will move to the side of least resistance so if you tighten the left side the belt will move right and vise versa. Good luck. You can contact Techmotionusa.com if you need phone support or service.
Treadmill Repair Fitness Equipment Repair Parts Services Fitness...
SOURCE: My Treadmill Belt slips as soon as any weight is
I have the same problem. The white wheel on the end of the front roller is probably stripped out, and it spins when weight is applied. You can order a new front roller online for around $100.
SOURCE: Proform Crosswalk Dual Motion Cross Trainer
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
SOURCE: Proform Crosswalk Advanced 525X
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
SOURCE: Need to replace 15 amp fuse on ProForm Crosswalk
Remove the fuse and take it to any auto parts store where they will match it up for you. Regards, Joe
ps - kindly rate my answer. thank you.
SOURCE: Can I glue the torn edge of my treadmill belt?
I would question why it traveled to the right and cause you grief. Before anything else run the unit and see if its going travel to the right again if it does then check right end cap for breakage. To your first question no you cannot glue the belt they use a high temperature gluing process for the seams you'll have unfortunately replace the belt.
Testimonial: "Thanks for the advice. I'll check the machine as you suggested. "
