And the t.v power button shows white not red
SOURCE: Black box appears in middle of screen
go into the menu and look at the closed caption option----if TEXT is highlighted--this is your problem---select CC! or if it has it OFF.The TEXT will only appear on certain channels and it most likely was activated by someone changing the closed caption options. If this has been helpful give me a vote to let me know.
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
SOURCE: ''Select DTV channel for OAD'' screen and can't remove
**This is NOT a solution**
I was wondering if you were able to fix this on your own. I am have the exact same issue with a 42LG30
SOURCE: Lg 42lc7d turns on to blank screen doesnt respond to any request
I need sreen for LG 4LC7D-UB because the screen is damaged
