RCA R52WM24 52" HDTV Projection Television Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rca 7302rd5 56"hdtv tv looks like a 3d moive - RCA R52WM24 52" HDTV Projection Television
Anonymous
Level 3:
  • RCA Master 3,459 Answers
  • Posted on Aug 28, 2010
Anonymous
RCA Master
Level 3:
Answers
3459
Questions
5
Helped
850013
Points
5558
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
I have a rca 52 hdtv rear projection tv and it picture faded and it looks like u drunk seein double
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
1helpful
My rca hdtv has a 3d look, and it is blurry, what can i do
this 3d look is coused by bad convergance ics you have to replace them no adustment will fix this
3helpful
1helpful
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
1helpful
I got a 52 in rca hdtv projection tv and it went all 3d looking. is it able 2 be fixed or were they recaled i only have had it 2 yrs. this christmas would have been3 yrs
Ur convergence it dead,know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv repair kits.
1helpful
Looks 3d
Sounds like your Convergence needs to be adjusted. Go to your Setup Menu and look for Convergence. Choose that and the TV will automatically run it's Convergence program If that doesn't fix the issue then you may have to get the unit serviced
Picture looks like it is blurred as in 3d
Try colaberating the picture, if that doesnt work call the customer service number of the company of the tv
Screen looks like it is in 3D and no longer have access to the covergence setting.
Very easy repair you will need to replace FL231, DL231 and CL230 you can get them at the following link under RCA parts category and they send instructions. Cost about 11.00 shipping is free within the US
http://servicemanuals.vstore.ca/
Problem with my rca projection television
my RCA R52WH74 HDTV IS STARTING TO LOOK BLURRY. ALSOMY SCREEN LOOKS LIKE IT STRETCHING MY TV PROGRAMS....... CAN U GIVE ME A SOLUTION
2helpful
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
