Blades will not engage. It is clear of all trimmings and the engine still runs.
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
SOURCE: Husquavarna GT2254 runs fine till I try to engage the blades,
Hello janec37415:
>>From your Description it Sounds like the Seat Safety Switch is Bad, has a Bad Connection or the Stator/Charging Coils are Not Charging Enough for the PTO to be Engaged.
>>When the Blade is Engaged, the Seat Switch is Showing No One is on the Seat so the Engine is Shut Off by the Safety System or
>>When the PTO is Engaged and the Stator/Charging Coils are Not Charging Correctly, the Carburetor Solenoid Does Not get enough Voltage to Stay Open and the Engine Quits.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: I have a Husqvarna CTH 171. When i engage the blades they
Does the lever that engages the blades have pressure on or does it feel loose. It is possible that the linkage from the lever to the idler pulley has come off. Raise the hood and watch the lever as it is engaged and disengaged there shold be somekind of linkage moving a pulley in and out to tighten the belt so the blades will turn. hpope this helps
SOURCE: Blades will not engage on Husqvarna riding mower.
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all debrie
