SOURCE: i want Asus P5N-MX Driver
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N-MX
There u go!, select your OS and download all the drivers you need
Good luck
Nic
SOURCE: Bios for Asus M2N68-LA motherboard to run on Win
If this is an OEM HP motherboard, you most likely won't find support on
the Asus website since they don't support OEM motherboards. Asus only
supports retail motherboards. You need to determine which HP/Compaq pc
system this motherboard came installed in, then check the OEM vendors
website to see if XP drivers are available. You won't find them on the
normal system driver page since it was only shipped from HP/Compaq with
Windows Vista installed. One such pc system that used this motherboard
is the Presario SR5019UK. I'm sure there were other pc models that used it as well.
Motherboard specs
A good place to start is the HP talk forums.
pls rate me FIXYA if u want more help
SOURCE: want the best bios for Asus M2N68-LA motherboard to run on win xp
You don't need to change the bios to do that, you already have the best one.
SOURCE: don,t have ASUS M2N68-AM SE2 Motherboard cd please
this took abit of looking but in the end im just unstoppable
DOWNLOAD SOFTWARE
SCROLL SOWN TO SELECT OPPERATING SYSTEM
hope i have helped you ...
SOURCE: i need a motherboard drivers
click the lick for ASUS M2N68-AM (Nvidia Geforce 7025) Motherboard Drivers
