Boating Logo
S
SUMMER Posted on Sep 08, 2014
What are the board measurments for custom floor on a intex excursion 4
What is the HP of an Intex 673R filter pump
It is a pump, only motors are measured in Horsepower. I would expect the HP of this above ground combined pump and filter is so low they would be embarrassed to state. It is measured in Gallons Per Hour flow rate.
https://www.google.com/search?q=Intex+673R+pump+specs
2answers
What is regulation height for a dartboard
Dart Board Measurements: Standard height from the floor to the bullseye on the dartboard is 5 feet 8 inches, while the oche (distance between the front of the board and the toeline) should measure 7 feet 9.25inches.
Nov 01, 2016 • Grilling
2answers
Height and distance of a dartboard
Discount Darts Dartboards and Accessories
Plastic tip: The toe line measures 8' from the FACE of the dart board, (not the front edges)
Steel tip: the toe line measures 7' 9 & 1/4'' to the FACE of the dart board. ( not the front edges)
Under both circumstances the center of the bulls eye is 5'8'' from the floor.
2answers
What does SPH MEAN?
When you have an SPH error it means you could have an over heated power pack, or you have a water flow issue, or possible damaged equipment. Here is the three trouble shooting items you can look for.
1. Your water temperature is lower then 60 degrees (Turn the unit off and let it cool down and then turn it back on, this may fix the issue)
2. Your water inlet or outlet is blocked or partially blocked (Clean the inlet and outlet of the hot tub)
3. Your heater sensor is not working (you may have to replace the heater element or circuit board)
The SPH Error and how to Fix
2answers
2helpful
How do I reset my combo locks on a 2000 excursion. I am 3rd owner and cant get original code.
Under the dash about dead center there is I believe a silver colored box that should have a tag on it with the digits for the door locks. I found it one time out of curiousity, and also on my 05 f250 but forgot to write it down. It is a pain to get to, but if you lay on drivers floor board, and look up almost behind the radio it can be found
1helpful
2answers
How do I hang the dart board?
When hanging a dartboard, you may try to follow theaccepted rules. The Throwing distance should be 7'91/4" (2.37m) and youshould measure a distance of "68 (1.73 m) from the center of the bulls eye tothe floor.
1helpful
Best way to locate and repair a slow leak in a intex seahawk 500 inflatable
Get some bubble bath, mr. bubble, or just dish soap, thinned out with water, spray it all over the boat, you will get it cleaned up and find the leak at the same time. When you see th e stream of bubbles coming out, mark it, get it dried off and patch it up. I think they use a contac cement on the Hypolon boats, or is it neoprene? Do you have a patch kit? Any pieces of material for a patch? The hardware store has pvc rubber used for shower pans, that might stick on there, clean it good with laq thinner, and brush on some glue, both pieces, let dry, then slap them together. You will know if it will work. Or else look up the manufacturers recommendations. he boat supply might have patch kits in stock. Hope this helps.
1helpful
2001 Excursion front end problems
The u-joint are know to dry out and never get greased. The ball joints will make noise while traveling over bumps and when turning.
Top Intex Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you an Intex Boating Expert? Answer questions, earn points and help others
