20 Most Recent Intex Excursion 4 Inflatable Boat Set Questions & Answers
HELP! My new little 200 boat will NOT INFLATE!
Hi, perhaps the problem may lie with the inflating method. Have you checked to see if the pump is actually giving air? These rafts usually have multiple bladders, are they all giving you this problem? Also, there is a plastic flap at the inside the base of the valve to prevent too much air from escaping before you plug it. you mush insert the air chuck adapter past this point. Good Luck!
11/15/2010 9:15:20 PM • Intex Excursion... • Answered on Nov 15, 2010
Best way to locate and repair a slow leak in a
Get some bubble bath, mr. bubble, or just dish soap, thinned out with water, spray it all over the boat, you will get it cleaned up and find the leak at the same time. When you see th e stream of bubbles coming out, mark it, get it dried off and patch it up. I think they use a contac cement on the Hypolon boats, or is it neoprene? Do you have a patch kit? Any pieces of material for a patch? The hardware store has pvc rubber used for shower pans, that might stick on there, clean it good with laq thinner, and brush on some glue, both pieces, let dry, then slap them together. You will know if it will work. Or else look up the manufacturers recommendations. he boat supply might have patch kits in stock. Hope this helps.
6/24/2010 2:17:12 AM • Intex Excursion... • Answered on Jun 24, 2010
What is the Dimensions and Material Type of Intex Explorer K2 kayak ?
The dimensions of Intex Explorer K2 kayak is 20 x 36 x 123 inches, and this kayak is used Vinyl Material. This is one of the best Inflatable kayak, To know about this kayak, you can check here kayakkkkk-unyjru5zr3glvfhi0dxmmnhr-4-0.jpg Intex Explorer K2 Admission Ticket to the World of Water Tourism
5/19/2018 10:59:38 AM • Intex Boating • Answered on May 19, 2018
What is the maximaum capacity and size of Intex Challenger K1 Kayak?
Maximaum capacity of Intex Challenger K1 Kayak is 220 pounds and the the kayak measures 30 x 15 x 108 inches (W x H x D). If you want to know all the details about Challenger K1 you can check this link , here you can gather the best knowledge about this kayak. kayak-unyjru5zr3glvfhi0dxmmnhr-4-0.jpg Intex Challenger K1 Kayak The Ultimate Kayak You Dont Want to Miss
5/19/2018 10:45:28 AM • Intex Boating • Answered on May 19, 2018
0answers
0answers
Intex mobile
Be the first to answer 2/17/2014 5:06:17 AM • Intex Boating • Posted on Feb 17, 2014Be the first to answer
0answers
0answers
0answers
0answers
0answers
3answers
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM • Boating • Answered on Dec 05, 2023
4answers
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin Cruisers are 20-40 feet. There are of course larger Yachts that can get to over 100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM • Boating • Answered on Nov 15, 2023
Diesel Boat motor cuts out under increased revs
I would clean the fuel filters and empty the water retainer filter then do some testing.
11/7/2023 9:11:35 AM • Boating • Answered on Nov 07, 2023
2017 Tracker 17.5 ft. boat. How can I remove batteries from it please.
Question edited for clarity. Question moved to Boating. Hello Anonymous Harriet :>D You will have two or possibly 3 batteries. Usually a large car type starting battery for starting the engine. Then two Deep Cycle Gel Batteries, one for the marine electronics, fish finder etc, and another that powers the front bow mounted Trolling motor. You will find them in the deck lockers. Open them, release any tie downs, undo the cables and lift them out for Winter storage. I keep mine in my garage and I put them on a battery minder for 24 hours once a month. I have the Battery Tender Junior, and I put them on a 6 amp car charger before the season starts. https://www.google.com/search?q=Battery+Tender https://www.google.com/search?q=2017+tracker+175+remove+battery The information you gave is is merely the year of manufacture, the maker and the length. They all have model numbers. That would be the key to searching for a manual online. https://www.jdpower.com/boats/2017/tracker-marine/pro-guide-v-175-wt__/32067137/specs and https://www.bbcboards.net/showthread.php?t=969900 ..
11/4/2023 10:54:05 PM • Boating • Answered on Nov 04, 2023
2017 Tracker 175 boat. Owners manual for it please?
Question edited for clarity. Question moved from Cars and Trucks to Boating. They don't list Manuals, but they should link you to one in their archive.
TRACKER Boats Learning Center
Tracker Boats https://www.trackerboats.com > learning-center PRO GUIDE V-175 WT · TARGA V-18 WT · TARGA V-19 WT · Jon Boats · GRIZZLY 1648 JON ... Owners. Warranty Information · Warranty Claim · Warranty Transfer · Order ...
11/4/2023 10:33:35 PM • Boating • Answered on Nov 04, 2023
Intex Excursion 4 Inflatable Boat Set Logo
2 questions posted
Top Intex Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you an Intex Boating Expert? Answer questions, earn points and help others
View Most Popular
Intex Boating
  • Intex Boating
Most Popular Question
best way locate repair slow leak in
  • Boating
