Why does My Dish Network DVR-625 receiver sound like a fan is running all the time on it even when it is turned off? Is this normal?
The Dish 625 as with the other Dish DVR systems has a fan built into the back of the unit. The fan runs nearly all the time to keep the internal drive cool. Sometimes the fan sounds louder that normal. what I do from time to time is take my shop vac and or the small vac u you use to clean your computer. and clean the vents around the fan. I do this on my desk top computer also.. Hope this helps.
SOURCE: I need to connect my Dish Network 625 DVR to a JVC
Providing you have enough input ports on the surround run you a red and white audio RCA jack from the receiver out port for TV1 and connect to the same colored ports on the satellite in ports on the surround. If you do not have enough ports then you may have to use the in ports on the DVD etc to run the TV through to utilize the surround system. Thanks for using Fix Ya.
SOURCE: my DISH Network DVR-625 DTV
ambrekulas,
I am sorry you are having problem with your picture freezing. You said you reset the receiver several times. Did you press the power on the receiver and release or did you unplug the receiver from the electrical outlet? Try unplugging it for about 10 seconds if you haven't already done so. If the problem persists, we'll need to replace the receiver. If you have any other questions, please post to this site.
Ray Calo
DISH Network
SOURCE: my dish network reciever vip622 dvr fan runs all
I have the same issue and find it unbelievable that the Dish Network DVR is so noisy. It's virtually a deal killer, except now I have the damn dish on my roof. Why can't Dish commission a better quality product?
SOURCE: DISH Network DVR-625 DTV Receiver- Is it possible
Hi gehrlichman, my name is Mike Houston of DISH Network andI was going over your post and seen where you were asking about an externalhard drive to get the recordings off your 625 DVR receiver. To do that you willneed to upgrade to our VIP HD series receivers, if you get the HD DVR receiveryou will be able to add an External Hard Drive to get the recordings off. Iwill send a link to tell you all of what's needed.http://www.dishnetwork.com/SupportSection/use-ehd
