Navman ezy 100t turns on, screen saver screen comes on, then navman goes to a screen that appears when it's plugged in a usb terminal (a computer, usb and navman picture, with a dot running back and forth between them). It's stuck on that screen weather it's plugged in a usb terminal or not. How do I get it to function properly or even factory reset it????????????
SOURCE: pin 570 wont boot after hard reset
RECENTLY I DID PRETTY MUCH THE SAME THING
SO HERE IS WHAT I DID :
" I TURNED IT ON AND HIT THE HARD RESET AND THEN LEFT IT ON TILL ALL P[OWER WENT AWAY FROM UNIT
SECOND I HAD TO DOWNLOAN A NEW VERSION FOR MY UNIT ; MEANING MAP
THEN I TOOK THE BATTERY OUT AND AND PLUGED IN MY USB CORD AND IT TOOK IT
I PUT MY BATTERY IN AND CHARGED OVER NIGHT AND WELL IT SEEMS LIKE A LOT TO DO BUT FROM WHAT I UNDERSTAND MY DRIVER GOT BOOTED OFF THE UNIT AND ANOTHER DRIVER FOR A MODEL WAS ATTACHED
HOW I DONT KNOW BUT MY UNIT WORKS NOW FOR THE LAST 4 MONTHS NO PROBLEMS
HOPE THIS HELPS YOU OUT RICHARD FROM CHICAGO
SOURCE: Navman f10
my navmanscreen went black now it shows a computer screen with anavman on other side with x on it could you help my email adress is [email protected] thankyou
SOURCE: navman f10
Hold down on/off button till screen clears,this should reset navman F10 .Turn back on and it should be working normally.this worked on mine.
SOURCE: Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
SOURCE: Navman S50 wont load maps
Hi, my probelm is very similar I turn it on and it shows a laptop, usb connection and the navman with a usb cable connecting them together,it also has circle running back an fourth
