Took out brew group to clean & inserted as per instructions but now coffee doesn't get dispensed. Instead soggy ground coffee ends up in grounds drawer & coffee leaks out everywhere (from under the coffee grounds drawer)??
I have followed all instructions from the manual, ie - lubricating the brew group & making sure all components are in their correct positions but have had no luck in solving this problem!
Had no problems prior to removing the brew group to clean it.
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
I had the same problem on my Vienna Deluxe. Try adjusting the grinds. here is a pic of what my sludge was looking like. Perhaps this will help
http://www.partsguru.com/user/Adjusting%20wet%20coffee%20puck.jpg
Coffee filter is very difficult to clean. Grounds stick to filter
COFFEE GROUNDS DUMP INTO DREG DRAWER WITHOUT MAKING ANY COFFEE
