Carburetor bogs out at full throttle.
SOURCE: how do you install primer bulb on husqvarna 125b
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
SOURCE: my leaf blower will start but wont run
fuel system needs cleaned
check fuel lines
filter
remove carburetor for replacing diaphragms/gaskets
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
