20 Most Recent
Husqvarna 28cc Hand Held Blower HVH 125B Questions & Answers
Where can I get a fuel line routing diagram?
Just go from the fuel tank straight to the carb and the primer. The pipes are a set length so you don't have to worry about threading it all around the blower.. just take the most direct route from the tank to the carb..!
Wont draw a prim
check primer bulb for cracks and leaks .
check hose into the fuel tank for cracks and leaks
pull the carby apart and replace stiff diaphragms.
New Husqvarna 125B blower runs fine then stalls
Is the gas fresh or old that you used. Since this brand new, it's under warranty. If you've had it for a few days, return to the store from which purchased it. It should run right out of the box without having to work on it.
