SOURCE: Issues with Streamer Sport Model 888WA power chair
please can you tell me how ofter the light's flash ? does there appear to be some kind of sequence ?
SOURCE: shoprider 4 wheel sooter breaks locking and have a wiring problem
if the wheel lock , then the brake must be faulty, so please clarify does the scooter work okay when you push the forward or reserve lever ?
Remember the brake release when you push the throttle lever by applying 24v to the brake , if the brake does not click then the brake might be faulty or the controller is not outputting24v ,check the wiring and connector from the brake to the controller.
SOURCE: Can I put higher Ah batteries in my Shoprider Streamer?
Absolutely. Let me explain what "Ah" means. "Ah" stands for Amp Hours. A 32ah battery will run a 1 amp motor for 32 hours...or a 32 amp motor for one hour...a 16 amp motor for two hours etc.. As long as the battery voltage is the same it's absolutely fine. As long as your chargers are the correct voltage, they'll be fine as well. So basically, the higher the "Ah", the longer the battery will last. This is why higher "Ah" batteries are more expensive. Hope this helps : )
