Asavings Panasonic KX-TGEA20S Dect 6.0 1 Digital Cordless Handset 3 Vtech LS916 Retro Handset for Cell Phones Logo
M
MITCH MARSHALL Posted on Aug 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WIFE`S CELL PHONE # IS BLOCKED, BUT IS NOT IN BLOCKED #S
WE RECENTLY PURCHASED LAND LINE PHONES MODEL KX-TGEA20.I BLOCKED A LOT OF #S, BUT NOT MY WIFES CELL PHONE. WHEN SHE TRIES TO CALL OUR PHONE THE CALL IS BLOCKED AND HER ID IS "PRIVATE CALLER" THIS IS VERY BAD BECAUSE SHE CAN`T CALL HOME. I HAVE REMOVED HER CELL # FROM THE CALLER LIST AND THE QUICK CALL LIST AND SHE DOESN`T SHOW UP IN THE BLOCKED LIST, BUT STILL SHE IS BLOCKED. CAN YOU HELP US?
Thomas Stauber
Level 3:
Master:
  • Master 438 Answers
  • Posted on Aug 26, 2014
Thomas Stauber
Master
Level 3:
Master:
Answers
438
Questions
Helped
90703
Points
1054
Have her dial *82 before she dials the home number. If that works she has the cell phone set to block her number. *82 should unblock it for just that one call.
2answers
Panasonic KX-TGEA40. Why cant callers hear me on my Panasonic kx-tgea40?
Question edited for clarity.
Question moved from Misc.
You pressed the MUTE button.
I'm not using a land line with my Panasonic KX-TGD560 and only have my cell connected to it via Bluetooth. How do I clear the "Check Tel Line" message since I'm not using a "Tel Line"?
Check Tel Line means that the phone is not getting a dial tone. Unless you connect the KX-TGD560 base to a RJ-11 phone cord going to a RJ-11 jack with a working telephone service, this message will continue.
I've never used the cell phone link without having a land line connection. The Link-to-cell option for using the handset on Cell 1 (or Cell 2) may still work. You need to have a compatible cell phone close to the base. The phone needs to be positioned where it gets good signal strength. Test this yourself.
I hope this helps.
(Panasonic has the manuals and a trouble-shooting guide for the KX-TGD560 here: http://eng-ca.faq.panasonic.com/app/answers/detail/a_id/55826/~/product-guide---telephone---cordless---model-kx-tgd560%2C-kx-tgd562%2C-kx-tgd563%2C . )
No Key Sounds, No Speaker Sounds, No Ringer Sounds on KX-TGEA20
https://www.justanswer.com/phone-systems/aaeg0-off-turn-off-silent-mode-kx-tgea20-phone.html
look for answer in above web link
"OK - I have the instructions for you below.
1) Using a handset, while the system is not busy (not on a call),"
I am not going to copy the whole answer in case copyright exists for just answer web site content
KX-TGEA20. How to clear my block menu full so I can add to numbers to block.
To erase a number from your blocked calls list;
  1. Press [MENU] [#] [2] [1] [7]
  2. Press the [?] or the [?] button to select the telephone number that you want to erase.
  3. Press [ERASE]
  4. Press the [?] or the [?] button to select [YES]
  5. Press [SELECT]
  6. Press [OFF]
May 5, 2017
How do I unblock a number on a kx-tgea20 handset ...
https://www.justanswer.com > ... > Phone Problems
I have a Panasonic cordless phone KX-TGEA20. I cannot figure out how to unblock numbers that I blocked by mistake
Telephone number blocking is done by the phone provider service, not the phone. Many are *60, then follow prompts.
User Manuel for panasonice cordless phone kztgea20
Do you mean the KX-TGEA20 cordless handset? I don't know of any KZ models in the Panasonic product line. If you do have the KX-TGEA20 handset, then Panasonic has the manual here: ftp://ftp.panasonic.com/telephone/om/kx-tgea20_en_om.pdf . You can also find the manual on the product page, http://shop.panasonic.com/search?q=KX-TGEA20# . Select the S or B suffix depending on the country in which you use the phone.
If you need additional information on using the handset, check the manual for the base system. The KX-TGEA20 works with the KX-TGE210 and other models. The KX-TGE210B manual is available here: http://shop.panasonic.com/support-only/KX-TGE210B.html . The direct link is ftp://ftp.panasonic.com/telephone/om/kx-tge210_mul_om.pdf .
I hope this helps.
Top Asavings Lands Phones Experts
k24674
Are you an Asavings Lands Phone Expert? Answer questions, earn points and help others
