Fujitsu Siemens ESPRIMO MOBILE V5535 Laptop Universal AC Adapter 18-20v (AC22VPNVK5EA7) Logo
A
Alan Posted on Aug 25, 2014
The cursor will not move I think I have locked the touch pad by mistake
The cursor will not move when I touch the mouse pad on this laptop.
JOSELITO YARA
Level 1:
Habit-Forming:
New Friend:
  • Contributor 37 Answers
  • Posted on Aug 25, 2014
JOSELITO YARA
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
37
Questions
Helped
6290
Points
62
Use a temporary external USB mouse, Click Start button from your laptop. Type "mouse" in Search Program & Files, click mouse under control panel. click Hardware tab,click properties, click change settings, click driver tab, check if the device is enable or click update diver or rollback driver if necessary.
I have a toshiba 6100 and the cursor wont move unless i connect mouse
Make sure you have not pressed the little button right above the mouse pad that toggles between locking the mouse pad or freeing the mouse pad.
1helpful
2answers
Mouse pad cursor works but cannot click
my laptop pad is not working the cursor is moving but not clicking on anything ......now wot can i do ???
Curser will not move
Hi and welcome to FixYa!
If you are using the touch pad and the cursor will not move, you may want to try and use a mouse. The touch pad on your computer may have worn out. If the mouse works, it may be your pad.
Please check to make sure that touch pad button is on. If the mouse will not move the cursor, your drivers may have been corrupted and you have to download new drivers after uninstalling the old one. Which one you download will depend on what type of computer you have.
Thank you for asking FixYa!
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
Cursor jumping, pages scrolling on own
bad mouse action , no other words need be said just that.
NO OP SYS STATED BY YOU< XP?
if the mouse is a wireless mouse, the battery is dead.
if the 1 mouse is wired it is bad.
if there are 2 mice connected , shut one down 2mice not allowed.
if the mouse pad is enabled then that is 2 mice if usb mouse used.
and not ever good to do that,
disable one of the mice. (easy no? rules)
i disable my LT here, , in control panel, device manager , mouse pad synaptic or what ever it is.
RC right click disable, it , I hate mice pads././/
Mouse laptop not working
Touchpads have a cursor lock that suspend the use of the touch pad but allow you to use a mouse. Ensure that the cursor lock is not on. That lock is a thin strip just about the touch pad. Usually, it will light up when it's turned on. If you have that lock in the off position then I would not recommed that you go probing inside your laptop to relsove this issue. You should take your laptop to a qualified tech for repair. That laptop has to be disassemble to resolve any physical problem with the touch pad. You will overwhelm yourself with all the little pieces of computer parts and create a larger and more costly problem for yourself.
Hope dis is helpful...
7helpful
3answers
No cursor activity
Dear Sir,
Generally for compaq there is lock for touch pad you can see a moving lock below or above the touch pad. If locked the tochpad button,touch pad not sensitive.So open the lock and now you can move pointer using touch pad. see this pic
http://icerazerstudios.com/wp-content/gallery/random%20images/touchpad.jpg
there is black color button lock appear at the upper border of touchpad.
13helpful
2answers
My toshiba laptop cursor doesnot move when i touch the tray pad
Hi!
I had the same problem after my fat cat sat on my keyboard. This is how I fixed it. At the top of the keyboard there is a F9 key. If you look closely at this key, it also has two pictures of the mouse pad. This key is a toggle that turns the mouse pad on and off. Down near the lower left corner of the keyboard is a key marked FN. Hold down the FN key and press the F9 key. That will turn the mouse pad back on.
BTDT, HTH
3answers
Mouse moves on its own
Your palm might be brushing on the touch pad while you are typing that is probably why the cursor jumps to a different location. as for disabling the touch pad I think that it is not possible unless you install a synaptics driver for your laptops touch pad.
20helpful
Toshiba Laptop Satellite A15-S157 Mouse Cursor stuck in one place(Locked)
To get enable or disable the Touch Pad you have to pulse the Fn + F9
You can also set this function as follow:
Start >> Control Panel >> Printers and other hardware
Click Mouse >> Touchpad (enable or disable)
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
