Will not power on - red power light is flashing
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
SOURCE: my samsung tv LE32S73BDX/XEU will not turn on red
sounds like the power supply board has failed and should be replaced. most common problem for all samsungs.
SOURCE: my 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
SOURCE: I am having problems with
Your problem is typical of Samsung LCD TVs. The capacitors on one of the internal boards are rated at 10V and should be higher. If you open the case, you'll see bulging capacitors. If you can handle a screwdriver and soldering iron, you can actually fix it yourself with a few capacitors from an electrical supply store. Simply read the specs off the bulging capacitors and get a higher voltage-rated replacement. For exmaple, if the capacitors say "1000uf 10V 105C", you would replace them with "1000uf 35V 105C" or similar rating. Or an easier method: Recently, Samsung themselves have been making repairs as it is such a widespread problem. Call Samsung at 1-800-726-7864 and they may just repair it for free, even if its not under warranty.
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
SOURCE: Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
