I am running KitKat 4.4.4. Google Now used to display all of my notifications with no problem. However, recently I have noticed that Google Now is not displaying all of the notifications that it should be displaying for me such as appointment reminders, traffic notifications and GMail Notifications, I have even tried to do this on a replacement phone that Verizon Wireless sent me THE REPLACEMENT PHONE IS ALSO A MOTOROLA DROID MAXX XT1080 16GB. The steps that I have used to get to the Notifications setting that I am refering to are. 1. Going to my HOME-SCREEN and TAPPING ON APPS 2. TAPPING ON GOOGLE SETTINGS. 3. TAPPING ON SEARCH & NOW. 4. TAPPING ON NOTIFICATIONS When I try to tap on the bottom option, which is supposed to display such things as APPOINTMENT REMINDERS,TRAFFIC NOTIFICATIONS and GMAIL NOTIFICATIONS nothing happens, for some reason that option is disabled. When I first started using this phone afew months ago the notifications that I have listed above were working just fine, they suddenly stopped working for some reason though, I SHOULD ALSO TELL YOU THAT I DO USE WI-FI QUITE OFTEN!!!.
Todd-
Can you provide some screenshots from your phone? Push down volume and power button to take a screenshot.
Take a screenshot of
You can also visit the MOTOROLA DROID MAXX XT1080 Community: DROID ULTRA ULTRA MAXX
Mark
Motorola Support
SOURCE: Motorola E815 alarm quit working
I've had a similar problem with alarms not going off. In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off. Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes. The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
SOURCE: Motorola V3 RAZR won't charge!!!
hmm well i suppose u try with a new charger 1,, b4 you throw it away
SOURCE: my phone displays 'unable to charge' or no battery icon?
I plugged my phone up and all of a sudden got the message "Unable to charge" on it. I changed chargers (i had an extra one), i changed batteries (i had an extra one), and i swapped every combination imaginable.
My solution....
My Razr's plug has an opening to plug the phone that resembles a person's navel, and it got dirt and dust bunnies in it while it was in and out of my pockets. I was able to take an old tooth brush (or your new one if your really desperate), and got a can of office duster that you use to clean keyboards. Turn the can of office duster upside down for a second while you are spraying it and liquid will come out as you are spraying the connector. Immediately after that, use your toothbrush to work it inside the dirty connector to free it from anything that will keep it from making good contact. Then, hold the can of office duster upright and it will only spray air... and blow the connector free of anything that you loosened with the brush. Repeat this process if after all this it still doesn't work... because you have a REALLY REALLY dirty connector if it doesn't work after the first try.
SOURCE: my droid is running very slow
Hi there ... Have you inquired of Verizon as to a solution to this trouble? 1-800-2JOININ 24/7. They are the experts. My wife's Droid runs lile a Deere is chasing it.
Thanks for using FixYa.com
