20 Most Recent Insignia - Flex 8 inch Tablet with 8GB Memory Questions & Answers
I got a insignia tablet flex 8 that has windows that is locked.
PDF]USER GUIDE Insignia Flex™ Android Tablet
www.insigniaproducts.com/.../NS-14T002_13-0622_WEB_V1_ENG_Fi...
Oct 11, 2013 - 8. NS-14T002 Insignia Flex™ Android Tabletwww.insigniaproducts.com. Setting up your .... Unlocking and relocking your tablet. When you turn ...
NS-13T001 Insignia Flex™ Android Tablet
www.insigniaproducts.com/cms/documents/manuals/tablets/.../help.html
Creating a screen unlock pattern ... Your Insignia Flex Tablet represents the state of the art in Android tablet ... Your tablet's internal storage capacity is 8 GB.
Insignia (Bestbuy) Flex 10.1 Tablet unlock - XDA Developers
forum.xda-developers.com > General discussion > Questions and Answers
Jan 17, 2014 - 3 posts - ‎3 authors Insignia (Bestbuy) Flex 10.1 Tablet unlock Questions and Answers. ... UnlockBootloader, Install TWRP and Root the Huawei Mate 8 ... the tablets bootloader isUNLOCKED already, I tried the OEM unlock command in adb and ...
Creating A Screen Unlock Pattern - Insignia NS-14T004 ...
www.manualslib.com > ... > Tablet > NS-14T004 > User manual
You can increase the security of your tablet by creating a screen unlock ... 101. NS-14T004 Insignia Flex™ Android Tablet ... Wi-fi windows 8" tablet (86 pages).
4/30/2019 1:13:40 AM • Insignia - Flex... • Answered on Apr 30, 2019
Can you connect a external hard drive to in sign a flex 8 tablet
Most likely yes. You will need OTG cable. You will need external hard drive with own power supply or tabled may not be sufficient to power up hard drive. It is safer to use usb stick
10/16/2016 3:25:39 AM • Insignia - Flex... • Answered on Oct 16, 2016
Can you connect a external hard drive to a insigna flex 8 tablet. Keep getting message running out of memory storage
Most likely yes. You will need OTG cable. You will need external hard drive with own power supply or tabled may not be sufficient to power up hard drive. It is safer to use usb stick.
10/15/2016 11:22:44 PM • Insignia - Flex... • Answered on Oct 15, 2016
Can't get apps to remain on sdcard after firmware update
They probably are still on the SD card, but the apps directory index was overwritten in the main memory. Also, the app data is usually stored in main memory, so you would still loose your data settings part. Read card on a computer and see if you find .apk files on the sd card. they may be hidden files. but you can not recover the data settings part unfortunately. preventative backup is always the best. If they are google apps, make sure you backup to google in your google account settings use your carrier backup to cloud for phones.
9/21/2016 11:58:36 PM • Insignia - Flex... • Answered on Sep 21, 2016
How do I open my other Facebook account?
when logged in to facebook, select upper right triangle down, find log out, and log out. then you can sign in again, with your other email address, you will need that. you can reset password if you need to. you can do this to switch between the 2 accounts. if you don't want an account, log in, then choose the padlock upper right , then More settings. on the left, choose security. In middle of screen at bottom, you should see deactivate my account. choose edit on the left.
9/21/2016 11:39:15 PM • Insignia - Flex... • Answered on Sep 21, 2016
How do I get the back off
4/7/2016 3:23:28 PM • Insignia - Flex... • Answered on Apr 07, 2016
0answers
0answers
Internet connecting
Hazel, I can only suggest that you check that WiFi is ON and aeroplane mode is off. After that I'm at a loss.
7/27/2015 12:07:29 AM • Insignia - Flex... • Answered on Jul 27, 2015
When I turn on my tablet the screen that just shows my name and time and some dots. if you cannot do the dots in the correct pattern you cannot get to the main menu. Where can I get to the main menu
The "dots" on the screen are the security measure and require the correct pattern to unlock. This was enacted by someone (yourself or someone you know who had access to the tablet) as a measure to keep others out of personal information. I would direct you to the insigniaproducts.com website for instructions on a hard reset of the tablet. Keep in mind that the security solutions are designed to keep others out of your tablet. If this was your intention, it is working too well. Choices are limited...remember/figure out the pattern, or reset the tablet and loose all data. I'm sorry this happened but there's really no "crack" or shortcut around the security measure.
3/16/2015 3:30:06 PM • Insignia - Flex... • Answered on Mar 16, 2015
2answers
How can I connect my insignia tablet to a keyboard?
Hi Roberta Perhaps an Incompatibility. Time to Rely on the Warranty... It does have a warranty... right If Not.... There is a service agent or even the people you bought it from! When buying electronic products it's times like these that you need good customer service. I try to think of this just before buying my product.... even if it costs a bit more. apple costs more but it's dependable Good Luck
3/7/2015 1:27:44 AM • Insignia - Flex... • Answered on Mar 07, 2015
Does insignia 10 inch tablet use sim card
Of all the Insignia tablets, there is only one that will use a SIM card. It is specifically called out in the model number as an LTE capable unit. The model numbers are the NS-15T7LTE and the NS-15T8LTE. No other INSIGNIA tablet will have a SIM card slot available.
3/6/2015 5:01:30 PM • Insignia - Flex... • Answered on Mar 06, 2015
Insignia - Flex 8 inch Tablet with 8GB Memory Logo
Popular Tags
51 questions posted
Top Insignia Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Insignia Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Tablets & eReaders
Most Popular Question
connect insignia tablet keyboard
  • Tablets & eReaders
